Re: Yellow Staining, Acorbic Acid Works Well, BUT.....
Your cya is very high. Is it possible to do a partial drain and refill? You will have to get your chlorine up to 25ppms to shock, and a minimum of 8 just to keep it sanitized. Sometimes after the ascorbic acid treatment the water gets cloudy. A partial drain will help the pool to clear faster, but is your fill water the problem, or do you think the metals came in another way? If it is your fill water you will need to put in more sequestering agent when filling. What is your calcium level? If your calcium level is high and your alkalinity is at the high end you can be getting some fallout from that, which will cloud the water and the only way to get rid of high calcium is to do a partial drain. You can also use skimmer socks. Otherwise you just need more POP - pool owners patience
Northeast PA
