Re: AG Pool vacs?
I too have been burned by opened packages.
Wanda will occasionally tip over, especially if there are obstacles in the pool that get in her path. The hose segments will get to the point wherer they will curl and keep their shape, so I have now started to rotate them in the string and even will leave them on a hot pool deck or sidewalk in the sun to relax the plastic.
Good luck
BTDG
