Welcome to the forum.
It is ok to use muriatic acid in a vinyl pool. You do want to add it while the pump is running. (No slug method.) What is your ph? Do NOT add 1/2 gallon. Repost with your ph and someone will help you go from there. Actually, please give us a compete set of current water testing results taken with a drops-based kit -- not teststrips.
