Results 1 to 10 of 11
Thread: Am I on the right track?
    Default Re: Am I on the right track?
    Hi Tabitha, and welcome to the forum!! You're definitely on the right track to getting your pool clear! It's obvious you've done your homework and once you get your pool cleared up, it'll amaze you how easy it is to maintain!!
    With a CYA of 60, you aren't at "shock" level with the chlorine til you get to 20 ppm. To clear up the green, you need to get it up to 20 and HOLD IT THERE as consistently as you can. You're doing a good job of checking and adding--just make sure you're getting it up high enough. IN a pool your size, each 2 cups of 10% chlorine will raise your Cl by 1 ppm. Maintain that shock level until the pool clears and until there is no decrease in CL overnight--test before you go to bed and once again in the morning before the sun hits the pool. When there is no CL demand overnight, then you can let the CL drift back down, but never less than 5 ppm. With a CYA of 60, you're going to have to maintain it between 5 and 10 ppm to keep it algae free. Keep the filter running, backwash as needed, just like you're already doing.
    I don't really understand why your pH is rising like that--chlorine has a pH of somewhere around 13 but usually the noticeable rise in the pool is fairly temporary. You can still add acid if you want to keep it in the low 8 range, but remember that pH shows falsely high when the chlorine level is above 10 or so. I wouldn't worry too much about that right now, it's fairly easy to fix after you get the pool clear, and it will also help with your TA too.
    Hang in there!!
    May 2010
    Update: Cl was holding steady at 5 ppm for 6 hours, so I decided to start adding more. The pH came down to 7.4 , by the way, I'm not going to worry about that for now.
    I've added another 6 gallons of 10% Cl and every time I add it, it either doesn't go up or actually goes DOWN a little! I am amazed at how much Cl this thing is eating. I sure hope it slows down soon. It is hard to trust in this process and not just break down and go to the pool store for chemical warfare (just kidding). I've never added algaecide, and not ready to give up yet!
    I have to go buy some more chlorine...
    May 2010
    Oh, now I am really confused. The FC reading is now ZERO!!! What's going on? It was holding steady until I started adding more. I even diluted the sample to see if it was getting bleached out and it still said zero. I happened to have a crummy old test strip so I used it to cross check and it is reading 20+ ppm chlorine. The water does not look better. It might look a little worse now than earlier today. Any suggestions?
    May 2010
    Well, I figured it out. My Cl is around 60 ppm! I had to dilute the pool water a lot to get the test to read. Guess it was bleaching out the reagents. Thank god I reached the breaking point. Now I hope for the best...
    Run your pump/filter to get all the dead stuff out--a Cl of 60 ppm oughta do the trick! Remember that the bleach kills the algae and should turn the water blue/cloudy, but the filter gets the dead stuff out. If you'll test for Cl at night after the sun is off the pool, and test it again in the morning before the sun hits it, when there's 1 ppm or less cl loss, then you can let your Cl drift back down into normal ranges.
    May 2010
    This morning the water definitely looks better. It is not yet crystal clear, but much improved over where we started. My FC is about 40 ppm now. I will check again at noon.
    Thanks for the words of encouragement. I was getting nervous there for a while!
    May 2010
    Hallelujah! After 5 days and 23 gallons of 10% Cl, I've reached the other side of the river Styx . Chlorine held at 20-25 for >8 hours even during the day, so I put some polyquat 60 in to help prevent regrowth and maybe clear the water just a little more. The water was pretty clear, but still just a little dull. Plan to put solar blanket on tomorrow morning and maybe will be swimming for the holiday. Yippeee! Thank you for your help.
  1. Am I on the right track...
    By my_youngminds in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-16-2013, 10:28 AM
  2. liner bead track
    By heatherc in forum In-Ground Pool Construction and Repair
    Last Post: 07-10-2011, 10:18 PM
  3. on the right track
    By clean~teeth in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2011, 06:25 PM
  4. Am I on the right track?
    By Sam_I_am in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-09-2007, 07:12 AM
