Hi, I am new to forums and pools. Acquired an existing home with IG Fox lined 16,449 gal salt water pool. Other than de-winterize and start up, not much help from the vendor. Was told to run 24/7 after adding 520 lbs of salt. Now that I've cleaned the pool and ran the pump 24/7 about 5 days and about 8 hrs per day 5 more, I need help on recommended normal pump time.
I understand that volume should circulated once every 24 hrs. Is that correct?
I have a quick guide for Fox pools but no guidance there. Also have on-line manual for the Digital Auto-Pilot and the Partain Whisper Flo WF-24 1hp pump but still no clue as to the run time needed.
No prior pool operation experience and I'd be so grateful for help.
