Thread: Cemented Main Drain and wall grate questions
    May 2010
    Illinois
    Default Cemented Main Drain and wall grate questions
    As my pool knowledge and confidence grows - so does my ambition :
    When we bought our house 7 years ago we were informed that the main drain in the pool had been cemented shut by the previous owner, due to a leak. These folks always took the cheap & crappy approach to problem resolution. The pool is a 12x24 (roughly) IG gunnite / plaster (I think) I'm kind of thinking of fixing the problem. I'm a bit of a novice at times - so here are my questions :
    1) Do I need a main drain for anything other than draining? Will it improve circulation a ton?
    2) How would I find the leak? Dig up the yard? What if it's "under" the pool?
    3) Would I have to jackhammer the cement (I'm guessing) to remove it? It could be quite thick I'd imagine.
    Also there's a small grate in wall of the deep end just below the coping. Maybe 5 or 6 " long and 2 inches high. There's a pipe attached to it - I can see the bend of a right angle pipe in the decking. I'm guessing it's to prevent overfill. Anyone know if this might connect to the plumbing?
    Thanks.
    -Rob
    mas985's Avatar
    Pleasanton, CA
    Default Re: Cemented Main Drain and wall grate questions
    If it was my pool, I wouldn't bother. It doesn't seem to be worth the effort. There have been some articles suggesting that main drains really don't add much to circulation.
    APSP Article
    Pool & Spa Article
    Mark
  1. I can't get my main drain to prime
    By Zac851 in forum Pool Equipment & Operations
    Last Post: 05-21-2012, 03:49 PM
  2. Main Drain Question
    By columbusdan in forum Pool Equipment & Operations
    Last Post: 06-05-2010, 10:33 AM
  3. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  4. Main Drain
    By bubsmit in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 02:58 PM
  5. Main Drain
    By nicole712 in forum Pool Equipment & Operations
    Last Post: 05-18-2006, 01:56 PM
