Thread: Pool Filled! Quick question
    May 2010
    Default Re: Pool Filled! Quick question
    Annak: Thank you much!! The PH rises all the time so I may be able to get in above 7.2 . I was more worried about an initial "shock".
    I do have a test kit. Not quite sure what FAS DPD means. but I do have all the little droppers and little vials. I put it in a little computer -- I think it's a colormeter... and it spits out the numbers for
    FC / TCL / PH / ALY / CH / CYA
    BUT NOT CC - but I am starting to think CC is TCL - Still havent gotten a grasp on the free chrlorine - used up chlorine - total chlorine thing yet.
    By the way my tester is a lamotte color q 7. I went that route as I am color blind.
    CarlD:
    I will be checking it every day at least 2 times a day and I will maintain it. I actually have it about 3.5 right now. I do believe I can add stabilizer today or tomorrow. He is coming over today to start doing chemicals. We just talked and I get the impression he wants to get the pool balanced. I am ok with it as long as he reads this forum first.
    I hate to sound arrogant, but I think I can now do it better then he can.
    I will ask about the Poly Quat today.
    I do have a calcium hardness question but I will put it in the right forum. That has me wondering.....
    Lehigh Valley, PA
    Since you have results for FC and TC you can calculate CC.
    Total Chlorine (TCl) = Free Chlorine (FC) + Combined Chlorine (CC)
    or
    TCl - FC = CC
    I know ChemGeek will faint at this simplistic explanation but CC represents the FC that's bound up with organics and is not available to do any sanitizing work.
    If your test and the subsequent calculation produce a CC of 1 ppm or more you may have an algae bloom starting even though your water is still clear. That's when it's time to shock the pool. However, as long as you stay on top of your water treatment with daily pH and Cl testing and add bleach as required you may never have to shock. I've had my pool for 5 years and haven't shocked it but once after a lengthy absence during which the pool was unattended.
    You'll get the hang of all this soon enough.
    Anna's got it pretty much right.
    I think TCL must be TC, so subtract FC from it to get CC.
    FAS-DPD is simplyh the best form of chlorine testing that's available to home or professional users. It can measure FC and CC up to 100ppm and is very accurate. It is not to be confused with DPD chorine testing, which can bleach clear at too high FC levels and make you think you have NO chlorine.
    FAS-DPD is a powder you mix into a little bit of pool water, which then goes pink/red. You then add drops of a reagent, counting drops until the fluid goes from colored to clear--each drop represents .5 or .2 ppm of chlorine (depending on which amount of water you use). You then add another reagent that picks up CC, and use the first till it's clear the same way. If there's just a tinge of pink and the first reagent clears it with just one drop, I'm not really worried...but if it takes more, Anna's right--something's cooking.
    May 2010
    Thanks guys!! I think I got it now.. .maybe
