Results 1 to 10 of 14
Thread: thinking of going with a swg
    May 2010
    Default Re: thinking of going with a swg
    I would be happy to share my info.
    I replaced my liner on May 7th, 2010 and have nursed my CYA up slowly so as not to add too much. I am currently at 50 ppm. Chem Geek and others on this forum advised me to go to 60-80 range on CYA.
    I purchased a "Box" of Muriatic acid containing two 1 gallon bottles about 10 days ago and I am still on the first gallon. I add about 2 cups every other day or every third day. I am hoping this will also decrease even more as I get dialed in.
    If you are asking about the additional electricity to run the SWCG alone it is negligible. If you are asking about running the pool filter and the SWCG longer than I did when I used traditional chlorine I have to say it is higher. I am expecting my first electric bill since installing the SWCG any day now, so I can't give actual numbers just yet.
    The trick is to get everything dialed in so you can run the SWCG system as little as possible so you prolong the life of the generator, slow the pH rise, maintain good levels of chlorine, keep your pool sparkling clean, and not spend a fortune in the process.
    See my newest thread in this section of the forum about fine tuning a salt water pool.
    Hope this helps. BTDG
    Thank you, BTDG, for the helpful additional info.
    I'll take a look at the other thread you mentioned and follow the progress there.
    Have a great weekend.
    Is it "A SWG" or "An SWG"?
    It is clearly "A Salt-Water chlorine Generator".
    I struggle with this linguistic conundrum.
    May 2010
    Well then, wouldn't it be "A SWCG"?
    It is not a Salt Water Generator, it is as you said "A Salt Water CHLORINE Generator.
    And while we're on the subject of conundrums, is it MURATIC or MURIATIC Acid?
    Severn, MD
    It depends on how you read the sentence. If, when reading, you say "A Salt-Water chlorine Generator" when you see "SWCG" then it should be "A". If you read it as "Ess - double_u - cee - gee", then it should be "An".
    As for the acid.
    As per: http://mw4.m-w.com/dictionary/muriatic%20acid
    It is: Pronunciation: \ˌmyu̇r-ē-ˈa-tik-\
    Regards,
    Mark
    pratzert is offline Lifetime Member Thread Analyst pratzert 0
    It's like the bit that George Carlin used to do.
    He would make fun of the inconsistancies of words and phrases.
    The one that applies here is when his friend was going to go out and buy a new "Hot Water Heater".
    Carlin asked him why he was going to buy a "Hot water heater" when what he really needed a "COLD water heater". Why did he need to make his hot water.... hot ?
    You say TOE-MAY-TOE and I say TOE-MA-TOE.
    So...how come everyone in the English-speaking world calls it "an MRI" not "a MRI" when it stand for "Magnetic Resonance Imaging"? (they took out the word "nuclear" because it made people nervous.)
    Carl, I think you've got WAYYY too much time on your hands!
