Thread: Intellichlor by Pentair Cell Light not on and other issues
    May 2010
    Default Intellichlor by Pentair Cell Light not on and other issues
    I have a pentair easytouch sysytem IntelliChlor - the cell light is not on (the cell was cleaned).... the salt reading is 2200, but the chlorine level when I test it is high and my ph is high.. I put ph down in the pool, but it has not changed levels.... I keep getting DE in the pool from the returns... any suggestions, advice???? Thanks alot.....
    May 2010
    Default Re: Intellichlor by Pentair Cell Light not on and other issues
    If your percentage is set to anything but 100, your cell light is going to be off according to the percentage. If it is set for 60% the cell light will be off for 40% of it's run time.
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
    May 2010
    Quote Originally Posted by TAS17 View Post
    I was wondering which product (dry acid - sodium bisulfate? muriatic acid?), how much is being added and what test you're using to determine this? Dry acid is usually contraindicated for pools chlorinated with a SWG; muriatic acid won't increase sulfates. What test kit/meter/strip is being employed to measure pH? In my pool, there is a rather constant acid demand -- not atypical for SWG pools -- however, a cup or two of 31.45% muriatic acid a week (for my 14K gallon pool) keeps the pH below 8.0. Recommend posting Total Alkalinity (TA) and pH numbers for more feedback.
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
