New IG liner and related work
I'm replacing my 11 year old 18x36 IG liner. After getting the old one out, I have several issues that I need advice on.
1. The galvanized walls have rust in several spots where the liner had leaks. The contractor recommends grinding the rust off, priming, and then covering with 3M wall foam. Seems like a foam would hold moisture next to the steel, not protect it, but I'm not a pool guy. I would use something like POR15 like I've used on cars, but again, I'm not a pool guy. I trust my contractor, but I'd like confirmation from the experts (waste, etc). thoughts?
2. The vermiculite bottom is rough and needs help. He recommends removing any bad spots and a "skim coat" over the whole bottom. Cost is around $1200 --- seems high, but it also looks like a lot of work.
3. Lastly, I need a new light as the one in the pool currently has no extra cord or wire (the current light has absolutely no extra wire, it will barely come out of the housing). He recommends a new light/cord combo with enough cord to get it up on the deck for future bulb replacements.
Thanks in advance for you advice. I lurk on here often and use the methods (and the kits when they were available).
...superjet
~25,000 Vinyl pool
Pure and Clear SWG; Hayward Pro Series filter
Purex Triton Minimax+ Heater; Magnatek Centurion 1 hp pump; PCS Infinity 2000 Cover
