Re: jandy lIte 2 fires when jumped but not from remote
If the heater fires when you short the fireman's switch, and that is where the automation (remote) is hooked up, then the problem is in the wire, or the automation. I realize that you are getting a short on the wire from the automation. Try disconnecting the wire at the automation end, twist the wires together, and see if it fires then. Then you will have verified the wire.
4 out of 3 people have trouble with fractions.
Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
