Thread: Check Your Spider Gasket (Thanks Poconos)
    Marietta, GA
    Default Check Your Spider Gasket (Thanks Poconos)
    If you have sand in the pool, and you can't figure out why there is air in the pump, check the spider gasket. I did everything you can think of to figure out my problem, including scooping all the sand out of the filter to check the laterals, replacing plugs, and replacing o-rings. The culprit was the spider gasket, and after a quick fix my problem is solved........for now.
    The fish that keeps on swimming is the first to chill upstream
    Elkhorn, WI\countryside
    Default Re: Check Your Spider Gasket (Thanks Poconos)
    I have a doughboy media master and I do notice a small amount of sand in the pool below the return. I replaced the gasket I think your referring to a couple years ago but it doesn't seem to me that I noticed any improvement at that time. Is there anything else to check?
    Sometimes sand blowing back into the pool is caused by an oversized pump for the filter, and sometimes it's caused by a crack in the laterals in the filter. Sometimes though, it's just dust/pollen/dirt/airborne junk that settles in the water and you can't really do anything about it but vacuum it up.
    Honesdale PA
    Glad to hear you resolved the problem. Those blasted gaskets can cause all kinds of problems because when they go bad you can get all kinds of unwanted flow paths, including lost water out the waste line.
    Marietta, GA
    This is very true, I also noticed water going out to the waste line the same time as the pool was filtering.
  1. Spider gasket adhesive question
    By keljoh in forum Pool Equipment & Operations
    Last Post: 08-16-2012, 05:32 PM
  2. Need a Hayward spider gasket
    By Bkirrane in forum Pool Equipment & Operations
    Last Post: 05-28-2012, 10:30 AM
  3. Spider Gasket
    By markphin in forum Pool Equipment & Operations
    Last Post: 05-21-2012, 01:18 PM
  4. Spider Gasket - First Obsticle
    By Sprint54 in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2006, 10:31 AM
  5. Replacing Spider Gasket
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 11:49 AM
