Re: Frustrated
yesterday, I dumped 6 Gallons of Bleach, tested Chlorine last night and this morning, did not lose much chlorine. While i vacuumed the white Cristal chunks floated to the top, WHAT IS THAT? I heard it's water mold, if so how to clear it up? i got picture but don't know how to upload to the forum .ps: water still cloudy, blueish light green.
Re: Frustrated
Re: Frustrated
Cl 10
ta 100
ph 7.6
cya 55
Re: Frustrated
A FC of 10 is not high enough to clear up the green--with a CYA of 55 you need to have it consistently at 20 ppm. The more it drops, the longer it's going to take to clear up. Also, you said you "didn't lose much chlorine" overnight--how many ppm are you talking about in loss?
If the white in the bottom of the pool is crystals, then it's not water mold--I think it's probably undissolved cal-hypo that's been sitting on your liner all this time, since it's really difficult to pre-dissolve it. Vacuuming to waste or to filter is the only way you're going to get it out of the pool.
Get your chlorine back up to 20 and hang in there!
Re: Frustrated
but every time I add chlorine it just sits at the top of the water. it does NOT dissolve slowly like in previous years. this is the first year that I am experiencing this problem
Re: Frustrated
Unless your Calcium Hardnes (CH) is low, you shouldn't be using Cal-Hypo anyway. You didn't report your CH number -- do you have a good test kit such as the Taylor K-2006?
Cal-Hypo often has trouble dissolving well and can be pre-dissolved in a bucket of water first before adding it to the pool. However, it would probably be better for you to be using either chlorinating liquid or 6% unscented bleach instead.
Re: Frustrated
I would switch to bleach, that will stop the problem of it floating to the top. What is your CH? It's entirely possible that the CH has gotten so high that it just won't dissolve anymore.
Are you pre-dissolving it in a bucket of water before adding it to the pool? Have you tried pre-dissolving and then adding it through the skimmer instead of straight to the pool?
Ah, Chemgeek, we posted at the same time.....but at least it's proof that the advice is solid!!
Re: Frustrated
I have merged the pertinent info from the other two threads into this one, to make it easier to keep up with for the people attempting to help. Please continue on this thread! Thanks,
