Re: Frustrated
I would switch to bleach, that will stop the problem of it floating to the top. What is your CH? It's entirely possible that the CH has gotten so high that it just won't dissolve anymore.
Are you pre-dissolving it in a bucket of water before adding it to the pool? Have you tried pre-dissolving and then adding it through the skimmer instead of straight to the pool?
Ah, Chemgeek, we posted at the same time.....but at least it's proof that the advice is solid!!
Re: Frustrated
I have merged the pertinent info from the other two threads into this one, to make it easier to keep up with for the people attempting to help. Please continue on this thread! Thanks,
Re: Frustrated
My CH is at 100. I HAVE been using liquid bleach for the past 4 days.
Re: Frustrated
I can sense that you're really frustrated with this, and believe me, I understand why. We ARE trying to help!!
Is your filter capturing any of this stuff? How fast is your pressure rising and how often are you backwashing it? Have you tried the "adding DE to your sand filter" trick?
This is just an afterthought, but have you added any Baquacil, Soft Swim, Pristine Blue, or other PHMB chemicals to the pool? What did you add to it when you closed it before the winter?
Re: Frustrated
thank you for your patience. yes this has been very frustrating. the SAC is 5 ppm. the ph is 7.2 , the PA is 110, SH is 180, the CYA is 40 . The chemicals I have used recently is liquid bleach and hydrofloc. Yes I did the DE to my sand filter with very very slight results in terms of water clarity. My Calcium hardness is 180 which is low. It should be anywhere from 200-400 from what I understand. I have backwashed it 3 times in the past 5 days. I have not added Baquacil, Soft Swim, Pristine Blue, or other PHMB chemicals to the pool.
Re: Frustrated
When you added the Fiber Clear to your pool, how did you add it?
Re: Frustrated
I had added 2 lbs on Thursday night to the skimmer.
