Results 1 to 10 of 37
Thread: Chlorine and calcium low
    Default Re: Chlorine still low
    Can you post current water testing results. The last ones posted are now 4 days old. It would also be good if you could give us at least 2 of the following: FC, CC, TC, in additon to all the other test numbers.
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    Default Re: Chlorine and calcium low
    ok, I will try to get back to the pool store tomorrow and get a test done, I only have the strips.
    May 2010
    170 Elderberry Court
    I would suggest picking up the HTH 6-way test kit at Wally-World. It's made by Taylor, and while it's not a K-2006 or one of Ben's/TFP's kits, it's better than the strips - only thing it doesn't do is FAS-DPD chlorine.
    You have a bromide pool right now. It can take a while for the chlorine to hold after a sodium bromide treatment. Keep shocking the pool with liquid chlorine or bleach and you will find your chlorine will eventually hold. It can take 3 or 4 times before it does, however.
    Invest in a good test kit and stop relying on the pool store. You will never have your pool under control if you do. Get a Taylor K-2006 (not the K-2005). It is worth every penny (around $80 US) and will pay for itself over and over again. I know that NO ONE on here will disagree with me!
    May 2010
    Why are you adding bromine to your pool - not only does Cl and Br interact with each other, Br breaks down to worthless bromides quite quickly.
    You'll need to use bleach or liquid chlorine in huge doses to get the Cl levels up and you'll need to maintain them for a few days or weeks until the Br is down to 0.
    The Taylor kit that we recommend (that Waterbear mentioned in his post) can be found online for $55.00 at http://www.spspools-spas.com, or for $46 and change at http://www.amatoind.com . Believe me, a good test kit and your own testing will not only be more accurate, but save you HUNDREDS at the pool store.
    Quote Originally Posted by nthach View Post
    Sodium bromide is an effective way to kill algae (usually mustard algae) caused when CYA levels get too high. By converting the pool to bromine temporarily it takes the CYA out of the equation. However, once the pool converts back to chlorine the high CYA levels tend to create problems once again so unless there is also a water change to lower the CYA the use use of sodium bromide based products are only a band aid and not a cure!
    If memory serves, if you use a bromine to clear algae from a chlorine pool, you need to add lots of chlorine to get rid of the bromine.
    So you either add lots of chlorine to get rid of the algae, or lots of chlorine to get rid of the bromine that got rid of the algae....
    May 2010
    New York
    Cool Re: Chlorine and calcium low
    I received my test kit in the mail today. Here are the readings I get,
    Free CHlorine 0
    CC .2
    PH 7.3
    Alk 70
    CYA is showing > 100 is that possible?
    I will shock again tomorrow and try watermom's advice
    Yes, it is possible to have a cya > 100. The cya test is the hardest test to read. Try it again and see what you get. If you have been using trichlor tabs for a long time, it may very well be over 100. If that is the case, if it were my pool, I'd do a partial drain and refill. (probably about half the water which would take your cya down to 50 and would be much more manageable.)
    Alk and pH are ok.
    Also, do shock the pool. How does the water look?
