Results 1 to 10 of 15
Thread: Problem Filter
    Default Re: Problem Filter
    I'm not the DE expert but I know the screens can be cleaned if they are not damaged. Pool stores will do that for a fee, but they soak them in muriatic acid to clean them. You may not need to replace them, but you may. If you replace the filter, you almost certainly need to replace the multivalve to get one compatible with your pool.
    At that time you CAN choose to stay with a DE filter or switch to sand or cartridge. That's up to you.
    If water is going in his skimmer and coming out dirty from what appears to be his low drain....something is probably plumbed wrong. Who puts a return so low in a pool? Of course it is POSSIBLE--there's no physical reason I know of not to put a return low.
    But if it is a low return, then simply properly cleaning the filter of that goo and re-introducing DE may fix it.
    Just some ideas.
    May 2010
    Thanks for the reply.
    I think I will just buy a new filter because my old one is just riped and the plastic is broken in some few spots, but if the things still come out then you think i should replace the multi valve.
    IMHO, if you replace your filter, you should replace your multivalve with it.
    Quote Originally Posted by Lenardo View Post
    If the grids are damaged, that will allow debris to bypass the filter (much like you describe). You can get replacement grids easily enough, but if you want a new filter - it's your pool and your choice.
    However you handle this, we'll be here to proffer our best advice to enable you to have a pool that is easy and less expensive to maintain
    (Jan, it's always my pleasure to be able to educate pool owners )
    [edit] Carl, the company I work for installs 3 'low returns' on every new pool and 'rehab'. The reason we do it is to more efficiently heat the pool and distribute the chlorine (usually from a SWCG)
    May 2010
    Thanks for everyones help.
  1. Filter problem?
    By marybee123 in forum Pool Equipment & Operations
    Last Post: 06-09-2011, 01:44 PM
  2. Filter Problem?
    By msb1766 in forum Pool Equipment & Operations
    Last Post: 08-24-2009, 09:33 PM
  3. Problem with DE filter-
    By freddyttt in forum Pool Equipment & Operations
    Last Post: 05-18-2009, 08:07 PM
  4. Do I have a filter problem?
    By justawildchild in forum Pool Equipment & Operations
    Last Post: 07-19-2006, 02:44 PM
  5. Filter problem?
    By Pamsel in forum In-Ground Pool Construction and Repair
    Last Post: 06-20-2006, 11:30 AM
