Thread: CYA test water doesn't get cloudy...why?
    Default Re: CYA test water doesn't get cloudy...why?
    Thanks, Watermom! I've been pc-disabled for a bit, but see your reply and it makes sense. I know I need to decrease the pH and alkalinity, but how does that affect the timing of adding cya? Which first?
    thank you for your super-prompt reply last time!
    Maureen
    Maureen
    16 x 32 Doughboy with 6' deep end; pool buried 24" into ground, backfilled with Doughboy-formula slurry; use sand filter, superpump, heater, automatic cover; 2nd season and still learning!
    It doesn't matter which order--the CYA addition won't affect the pH or TA readings. CYA is by definition an acid, but it doesn't seem to lower pH. The acid you'll use to ratchet the TA down with is muriatic, which is very strong and in liquid form.
  1. Cloudy water - CH test at 1900!?
    By tado921 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-26-2013, 01:47 PM
  2. Water cloudy, have test results
    By sbillingsley in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-01-2012, 03:07 PM
  3. Help with test results and cloudy water
    By superjet in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2006, 01:05 AM
  4. Test Results - Cloudy Water
    By quenterry0 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-06-2006, 06:28 PM
  5. cya-test water doesn't cloud at all
    By ValAZ in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-13-2006, 03:44 PM
