Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 40
Thread: Alkalinity?
    Default Re: Alkalinity?
    I added a whole box of borax Wed & Thurs. Tonight the numbers look good:
    TC = 3
    pH = 7.2
    Alk = 140
    Temp = 58
    So the alk is holding steady and pH is safe. Other than a lot of tree seeds in the pool it looks good. We'll clean the seeds up this weekend.
    Should I try to get the alk down a little lower?
    What is a good level to keep the Cl?
    I see in your first post that you say your cya is 40. If that is still the case, a cl level between 3-6 is your target. Alk is fine at 140. Leave it alone. At this point, I think you're good to go. Time to enjoy your pool! Glad we could help.
    Thank you so much for all your help. I learned a lot.
