Thread: Ideas for pool with low water level at opening
    Default Ideas for pool with low water level at opening
    Hi All,
    I took the cover off our pool yesterday, probably a bit impatient on my part but whats done is done. The pool is 16x32 ig, and probably needs about a foot of water. Since we are on a well, I have to have pool water trucked in. In the meantime, any ideas on how I can get some meaningful circulation in the pool? It very green, and I'd like to clean it up as much as possible before the new water is delivered, but I am afraid to put any chemicals in without proper circulation.
    Jeremy
    Default Re: Ideas for pool with low water level at opening
    You can go ahead and pour in some bleach around the perimeter of the pool and then stir it around with a broom or oar or something to mix it around. (Don't want to leave bleach just sitting there in high concentration near your liner.)
    Honesdale PA
    Another option is a small sump pump with a garden hose adapter. Suck from one end like the steps and discharge at the deep end.
    Thumbs up Re: Ideas for pool with low water level at opening
    Jeremy, it's great to see you again!
    I can tell you for a fact that getting chlorine in there ASAP will help! Even if you have low or no circulation, add the bleach and do as Watermom or Poconos said - if you do it tonight, you'll see a major difference tomorrow
    May 2010
    Do you have a bad well? Im on well water and always top off with that.
    You could drop the vacuum hose in the pool, hook up to the skimmer and run the pump, Just make sure you fill the hose with water first.
    cant you turn off the skimmer and just have the floor drain take water in to the pump? That way it does not matter how low the water is.
