Results 1 to 8 of 8
Thread: BBB vs Pool Store
    May 2010
    107 Baldwin Terrace
    Default BBB vs Pool Store
    Is it okay to switch to the BBB after using the pool store's chemicals without having to change the pool water entirely?
    Thanks!
    Lehigh Valley, PA
    Default Re: BBB vs Pool Store
    The short answer is: Yes.
    The long answer is: There are some specific techniques and processes to be applied, depending on what kind of sanitizer(s) you're presently using, the type of system you have, and your "numbers"—your water testing results.
    If you'll post some specifics we will be in a much better position to advise you.
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
    More simply:
    If you've been using any chlorine compound--pucks, powders, capsules, bags, you can switch to bleach / liquid chlorine immediately with NO negative effect at all. Bleach is compatible with salt systems too. Chlorine is chlorine.
    If you've been using Bacquacil, you have to go through a painful conversion but you'll be happier in the long run.
    If you've been using bromine, you'll have to drain your pool and refill, and then use lots of chlorine for a while.
    May 2010
    107 Baldwin Terrace
    I haven't used anything yet My pool gets installed this week. I want to do the BBB method, but pool company gave me a big box of pool chemicals. I'd like to use those up so they don't go to waste. I will stear clear of the chemicals you guys mentioned. Thanks for your help, this place rocks!
    What did they give you (ingredients). Have you bought a good test kit like the Taylor K-2006 yet? You can also go ahead and test your fill water. That way you will have an idea of the pH and alk of the water you will be adding and can plan accordingly. (You aren't filling from a well are you?)
    How smart you are, to be reading and learning ahead of time. Lots of people here with a big mess on their hands and wishing they had done just that!
    Yes, list the stuff they gave you. If it's useful, we'll help you determine that. If it's garbage, we'll advise you to chuck it.
    If they gave you stuff with names like:
    Clarifier
    Flocculent
    PhosFree (or other phosphate remover)
    Calcium flakes (and you have a vinyl liner)
    Algaecide (with a caveat to be explained)
    We'll suggest you don't use them. There is only one type of algaecide we recommend and ALL the others we recommend you throw away or give them to someone you don't like!
    If they gave you chlorine chemicals--powders or tablets, tell us what they are as well. Some are fine, at least for a while. Others (such as "Double-Acting" or "algae control added" ) may have bad stuff you don't want.
    But, the GREAT thing about B-B-B is that chlorine is chlorine and if you are setting up a chlorine pool with ANY type of chlorine you can be B-B-B instantly!
    So... let us know, and let us know the size and type of pool.
