Thread: Pentair Challenger Energy Efficient Pump
    MD.
    Default Pentair Challenger Energy Efficient Pump
    My 8 year old Pentair Challenger 1 HP Full Rated pump #345204 is now very noisy, and I am thinking it is time to replace it. Pentair makes what looks to be a model with comparable specs that is called 'Energy Efficienct' #345205, as opposed to standard.
    The energy efficient model is also about $50 cheaper. Does anyone have any experience with this EE model? I expected it to cost more. Is it a good pump compared to the standard? Thanks.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pentair Challenger Energy Efficient Pump
    This might be a good oportunity to switch to a two speed pump. The pump you are looking at is a Pentair CHII-NI-1FE which is a decent pump and fairly efficient.
    If you are willing to downsize a bit, the CHII-N2-1A is an uprated 1 HP two speed with a little better efficiency on high speed than the CHII-NI-1FE because it is a slightly smaller pump plus it is two speeds. Running on low speed will save you a lot more in energy costs.
    Do you have any other features that you will be running besides circulation? Waterfall, spa, cleaners, jets, etc.
    Mark
    MD.
    I got the energy efficient version of the same pump. It is on the way, so I don't have any more info yet. Pentair told me that it had all of the same power as the original, so I'm not sure why the would have the standard model.
  1. Replace old inefficient pump with new more efficient pump
    By TonyG in forum In-Ground Pool Construction and Repair
    Last Post: 03-28-2012, 04:59 PM
  2. Replies: 6
    Last Post: 02-26-2012, 12:06 AM
  3. energy efficient pumps
    By coldgin in forum Pool Equipment & Operations
    Last Post: 10-04-2011, 07:12 AM
  4. Best energy efficient pumps out there
    By jacksonlui in forum Pool Equipment & Operations
    Last Post: 10-12-2006, 01:38 PM
