Thread: Wiring a timer
    May 2010
    Default Re: Wiring a timer
    There should be a terminal block on the heater with a black jumper wire. This is where you make your fireman's switch connection. Remove the wire and connect your wires here. it is outlined in the manual (picture). If you don't have a manual, here:
    http://www.haywardnet.com/products/M.../Manual285.pdf
    Pg. 16
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
    May 2010
    I think I have it wired correctly. With the timer tripped, the display on the heater flashes "LO". Is that what I should expect?
    May 2010
    Will the heater only fire when your fireman's switch is closed?
