Thread: Intex saltwater system
    Jul 2006
    Default Intex saltwater system
    All the numbers are right on except the PH which is really really high. Any suggestions
    Default Re: Intex saltwater system
    You can use muriatic acid to lower pH. If you can give us some current water testing results taken with a drops-based kit preferably instead of test strips, somebody here can better advise you. Also, tell us what kind of pool you have and the volume and what all you have been adding to your pool (ingredients, not just "shock")
    By the way -- I moved your thread into the saltwater forum. Saltwater systems sometimes have chem levels and specifics that are different from regular systems. That way, you will get more appropriate suggestions for your setup.
    Welcome to the Pool Forum!
  1. Low Flow error with Intex saltwater system
    By lucky4you in forum Intex-type Pool Setup & Operations
    Last Post: 07-30-2012, 11:13 AM
  2. low chlorine w/ saltwater system
    By sjmathes in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-14-2012, 12:40 PM
  3. Doughboy AGP and an Intex Saltwater system?
    By Drpepper in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2011, 02:33 PM
  4. Low flow on intex saltwater/sand system?
    By digitaldoodlebug in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2011, 06:28 PM
  5. Intex saltwater system
    By LeeDavenport in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-31-2011, 07:31 PM
