Re: That massive pool restoration project
Happy New Year one and all. I've revitalized this thread to help familiarize all with this wild pool. Last year was a huge advance in the very very long history of this pool. Summary of progress: Complete filtration system installed and it worked fabulously. I installed the intelliflo 4 X 160 and ran it at about 50% rpm capacity for 10 hours per day. CRYSTAL clear with BBB method and I also bought a dolphin HD which is really a wonderful version of robotic cleaners for the 77 footer.
Now for this years fundamental question: Something here is slowly leaking and has done so for years. I just cannot find it. Not the new plumbing. Not the skimmers. Not surface cracks. Maybe the original and massive main drain valve. It's at least 12 feet below grade and frankly, not repairable without a world class excavation that might be a disaster anyway. If I simply assume I need to add water as I've done from a hose in the past, can I find a better and less risky water source than my well water?
I'm thinking of adding an above ground 1.5 hp and 18" sand filter which can be had for about $260 on ebay and drawing water from a stream that passes within 15 feet of my main filter setup. Could I tee into the 2" that runs from my main pump but before the TR140 with filtered stream water? The main returns are 2.5" but the pre filter side is 2" Yes, some algae would enter the system, but proportionally very small amounts. I use liquid chlorine at 12% and have no problem keeping clear water.
I know this is extremely unconventional, but this pool requires some thinking outside of the box. Frankly, we've got maybe a 90 day season, so the expeditious solution may be more sensible than the costly repair.
Regards,
Josh
If you insist on using the stream water then I would add the chlorine to that water and let it mix in some kind of holding tank before being discharged into the pool. I'm not that concerned with the algea but am concerned with the introduction of harmful bacteria.
Been using stream water for probably 6-7 years and no problem. I do run the chlorine up some after topping off but not to shock levels. Heck, people swim in ponds all the time. I use a small sump pump if I'm not in a hurry to fill, and run it into the skimmer with the pool pump running. This takes care of any dirt or stuff that may get sucked up. If I need a rapid fill, such as when I was chasing a 50 GPH leak, I used an old 1 HP pool pump. Then I pumped into the waste line, set the regular pool sand filter to backwash, and the filtered stream water came out the skimmer thus passing it thru the pool filter in the right direction. Obviously this assumes the stream is relatively clean and there isn't a chicken farm or something like that upstream.
Go for it.
Thanks Mark and Al!
My stream is mighty clean and is the source I fill from every year (after the acid wash down and 6 gallons of fresh acylic blue heaven on the bottom only) in Mid May with a 150 gpm trash pump. I can run the water directly into a 1" trichlor puck feeder, but I try to keep CA at 40 ish. The core of the question is really whether the tee idea will work. I want to keep flow rates up to 90gph and run the intelliflo to that level. Does anyone think I'll need a backflow preventer on the main pump side? Any hydraulically inclined minds care to weigh in?
P.S. Some of you thinking about new pumps might seriously want to consider this intelliflo. By throttling down to bare minimum turns per day and keeping ahead of the water, I added only about $50 per month to my power bill. Considering 85K gallons, I think this pump may pay for itself VERY rapidly. Just food for thought.
Regards,
Josh
I assume you wouldn't be running both the pool and stream pumps simultaneously. Rather than installing check valves I would just use ball valves and manually throw them when needed. Check valves do present some added flow resistance. PVC ball valves are also cheaper and you don't have to worry about any spring mechanism being affected by the chlorine.
