Hayward Pump questions
I currently have a Hayward Super Pump, 3/4 HP that has been in use for over 15 years. I feel that the pump is on its last legs as it's getting more noisy this year as time goes on. Sometimes it's fine and other times, it's very noticeable.
In any event, a little background: I have a Hayward Micro-Clear DE-3600 Filter (flow rate 72 GPM). The pool is an in-ground 16x32 vinyl, @20K gallons. I installed solar panels on my roof last year and the rise is about 25 feet. The pump has handled this perfectly fine, but I'm wondering if it could stand a bit more horse power (maybe it caused the current pump to work slightly harder and attributed to it slowly failing?).
My questions:
Would it hurt to get a 1 HP pump replacement or should I stick with the 3/4 HP? Or conversely get even more HP?
And the pump description says it "must be hard wired". My current pump simply plugs into a GFCI standard 115VAC receptacle and is controlled by a switch above. Hopefully "must be hard wired" means I have to manually add the power cord? Or does it mean it must be hard wired to the circuit (w/o the receptacle)? Obviously, the receptacle's convenient as I store the pump away for winter.
Regards,
Ron [ muvipix.com ]
