Between the hole, which started draining it, and the liner walls collapsing into the pool, the pool was drained when I discovered the damage.
It appeared to be okay about a week prior, when I last mowed my grass. I was mowing when I discovered all the sand around the pool. Pool went all winter without a noticeable problem, even surviving the blizzards, then this happened.
