Thread: Not sure if it is algae
    La Jolla, CA
    Default Not sure if it is algae
    Hi
    Former long time and regular user of the forum. I have a "rough and dusty" deposit on the vinyl walls. Not the typical mustard slimy algae. Water is clear. (until I brushed it off)
    pH 7.4. TC. 5ppm. FC 4.5. CC 0.5. TA 140. cya I keep around 10
    Indoor pool with indirect sunlight. Pool covered unless in use.
    I brushed the vinyl walls and increased the FC to around 10.
    It is going away but with my numbers I was shocked to get it in the first place. Filter always runs 24/7 because it has to. Only use standard bleach.
    Endless pool swimming machine.
    Any ideas
    Andy
    Default Re: Not sure if it is algae
    Hi Andy, welcome back--I remember you from years past!!
    Don't really know what caused the problem, because your numbers look fine, but my first knee-jerk reactions would be to suggest 1) Calcium trying to deposit? 2) Beginning of liner degradation due to a drop in pH around the winter? 3) "Crud" off the cover falling in when opening it?
    La Jolla, CA
    New liner.
    Recently filled the pool from scratch.
    Started about 6 weeks later.
    No crud on liner.
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  4. Green algae? Mustard algae?
