Thread: Risk in Draining Pool?
    Default Re: Risk in Draining Pool?
    Hey, welcome back to posting
    The trouble with draining an AG pool is liner shrinkage - the walls would still be sound. For an IG pool, you run the risk of it floating up out of the ground, if the ground water is sufficiently high. When liners are replaced, the pool dudes perform various acts of voodoo to keep the shell in the ground
    You could probably get away with taking out ~ 2/3 of the water - which would be a good refreshening of the water while keeping the liner set. Make sure there are no issues, minerals, high CH or alk, with the water you'll be pumping back in!
    waste, just wanted to thank you for your reply.
    Also, I did not drain; thanks to BBB/PPP/etc, water is now clear. It's amazing.
    Thanks again.
    Thumbs up Re: Risk in Draining Pool?
    I'm so very glad you were able to solve your issues without having to drain the pool!
    You show all the signs of being a valued contributor to the forum
    Thank You!
  1. Flow meter power control (solar heater risk mitigation)
    By pgiering in forum In-Ground Pool Construction and Repair
    Last Post: 07-30-2012, 03:21 PM
  2. Do not risk letting your pool freeze!!!
    By poolboy69 in forum In-Ground Pool Construction and Repair
    Last Post: 02-05-2011, 06:58 PM
  3. Draining pool
    By l1tech in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-13-2007, 08:11 PM
  4. draining pool, when would you really need to?
    By coryinsocal in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-15-2006, 10:24 PM
  5. At-Risk?????
    By chemistrydropout in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-12-2006, 10:13 AM
