Re: Sand in pool
Since you just changed to sand I assume that means a new filter and new sand. It seems normal to get a little sand out the returns from new sand but that should stop. When you backwash you should also do a quick rinse before switching to filter mode. The rinse position will keep anything that was stirred up during backwash from going into the pool. Only need to do it for 10 seconds or so. Of course the obvious question, you did use pool filter sand, right? When the sand was loaded the filter should have been maybe 1/3 filled with water first to keep the heavy sand from stressing the laterals at the bottom. Water will let the sand fill all the nooks and crannies as it is loaded and become evenly distributed.
