Thread: Problem with a heater
    May 2010
    Default Problem with a heater
    Hello I have an old RBI Galaxy Pool Heater. the model is a PH 250S I believe and I am having problems with it. it is a gas heater if I jump the TH-PP to the TH I can get the heater to fire up fora short period then it kicks off again. I believe my problem may be with the thermostat control as it has become very hard to turn and now requires pliers. does anyone know where i can get a replacement part? Also, I was considering just wiring a switch to the TH and TH-PP connectors so that i could flip a switch to manually jump them to the on position and turn it off when i desired. is there a risk to doing this? The local pool guys have no parts for this guy.
    Default Re: Problem with a heater
    Sorry, I can't help. Just wanted you to know you weren't ignored.
    May 2010
    thanks for the welcome! anyone have any ideas?
  1. Hayward Heater problem
    By bigred in forum Pool Equipment & Operations
    Last Post: 05-22-2011, 08:48 PM
  2. Heater Problem - Black Smoke
    By DaveV in forum Pool Equipment & Operations
    Last Post: 08-13-2009, 12:53 AM
  3. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 03:29 PM
  4. Help, I need a heater
    By viperbrock2003 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2006, 04:36 PM
  5. Laars LG heater problem
    By jmclennan in forum Pool Equipment & Operations
    Last Post: 06-08-2006, 09:38 PM
