Results 1 to 10 of 17
Thread: Absorbic Acid...How much?
    mbar's Avatar
    Ashland, PA
    Default Re: Absorbic Acid...How much?
    I would wait till all of the oxalic acid is gone - when the water is clear. If you are going to do the ascorbic acid, then I would raise the chlorine up high to get rid of the oxalic acid, and then let it fall back down to start the ascorbic acid treatment. It shouldn't take more than a couple of days. Make sure when you do the ascorbic acid treatment you also use a sequestering agent - I don't know if you used it with the oxalic acid - that may be why it didn't work so well. I never used the oxalic, so I don't even know what they reccomend on the container. Feel free to ask any questions you have.
    Northeast PA
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    On the Pool Stain Treat (oxalic acid) they didn't even say to use a sequestering agent, but from reading here I knew that I needed one so I went ahead and added Aqua Chem Metal, stain and Scale remover.
    Today my water is cloudy, no chlorine. I am going to have to try to get some chlorine in the water this evening.
    My problem right now is the alkalinity.. it is way high. How do I reduce it?
    The Ph was low so I added some borax and will check again in about an hour.
    Also, why do you not shock for 2 weeks after a stain treatment? I think I messed up because I shocked last night, 24 hours after the oxalic acid, trying to get the water to clear.
    Please help
    mbar's Avatar
    Ashland, PA
    THat may explain why the treatment didn't work. If all of the metals that were lifted off the surface of the pool weren't bound up by the sequesterant and you shocked, the metals would have fallen back out onto the surface of the pool. Often after a stain treatment the water is cloudy and will eventually get clear by raising the chlorine slowly, and keeping the filter running 24/7. Did it say on the oxallic acid not to shock? I know with ascorbic acid you should not shock for 2 weeks. If your alk is high, (I never had that happen with a stain treatment) then you have to keep your ph low and turn the return eyballs up so that the water bubbles on top to aerate the water. You can check the thread about alkalinity - ther is a sticky at the top of the page to explain the process. Don't get discouraged, feel free to ask any other questions you have.
    Northeast PA
    Jul 2006
    Upstate, SC
    I think my pool is trying to kill me.
    I have added a whole box of borax today trying to get the Ph up to 7.2.. so should I just leave it now (I just checked and it is still low) and turn the eyeballs up? I'm going to go back and read your post again carefully.
    I added some chlorine and a puck in the skimmer.
    How often can I test the water for changes, and hopefully improvements?
    This is really sucky to spend the 4th weekend with my pool out of whack I'm trying not to get discouraged but dang it! All this and I still have stains.
    I didn't shock until I was pretty sure the stain treatment wasn't helping... I shocked last night and still had 0 chlorine today. Oh and I had added a bottle of the AquaChem Metal Stain and Scale treat last week before I started all of this... I hope it helped some. The pool walls from what I can tell now look a bit streaky.
    Thanks for all your help. I'm new to all of this and trying to learn as much as I can as fast as I can.
    Oh, one more thing. My test strips show 3 ppm total chlorine but 0 free chlorine. ???
    Gerri
    Jul 2006
    Upstate, SC
    Oh also, on the oxalic acid it didn't say not to shock and also didn't say to lower chlorine to 0 - but I lowered the chlorine to 0 anyway hoping it would work better.
  1. Where to buy CYA? & acid ?
    By PJM361 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 01:13 AM
  2. Dry acid vs Muratic acid
    By jackinlv in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-25-2011, 01:44 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. Too much acid?
    By k2vell in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2006, 10:57 PM
  5. Dry acid versus muratic acid - and how to add?
    By west1745 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 01:19 AM
