Re: Brown water in pool- from Iron
You can swim anytime after using metal control. Just check the ph, some sequestering agents lower the ph and use up chlorine, so make sure both are in balance. You want your ph at the lower end no higher than 7.4 for the metal control to lift the recent stains off. High ph along with shock levels of chlorine will let any metals that are not sequestered to fall out of solution.
Northeast PA
