I've had a pool for over 20 years and somehow missed out on all this talk about aeration. My pool is 18x36 inground vinyle SWG. I pulled out the pump I use to clean the winter cover and dropped it to the bottom with the hose running up the side of the pool and then spraying onto the pool surface. Is there a better way? How long should I run this "aerator"?
Why am I doing this? I just decided to add Borax to my pool and I'm in the middle of adjusting the PH - it's high now (8.2) and I've added acid which I understand will lower the TA and I've read that aeration will in turn raise the TA back without raising the PH.
