Results 1 to 8 of 8
Thread: Pool Remodel: Tile Installed Incorrectly?
    Default Re: Pool Remodel: Tile Installed Incorrectly?
    You are correct the bond beam should be brown coated (built out with a suitable cement product) then use modified thin set for the tile then the grout.
    The problem with large amounts of tile setting mix is that it usually leaves voids behind the tile which will cause problems in the future especially in freeze thaw environments. I would ask for as much money as you can back and then hire another contractor.
    Hope this helps
    I have had about 50 tiles fall out of my pool this year after 30 years of few problems. Two different tile setters I had out to give me estimates said they do not use thinset and use a portland cement, binder, and (not sure about the last part) silica sand? mix. They both said they believe thinset is inferior to their custom mix. Certainly Laticrete and other thinset manufacturers would probably disagree.
    I would not be surprised if the proper thinset designed for exterior swimming pool use is probably essentially the same as what they are mixing from scratch. I know that the directions on the last bag of thinset I used said not to exceed a specific thickness, as it is a "thin" set.
    Unfortunately, "best practice" may not be the same as "common practice" in the industry.
    Jun 2010
    Regarding the grout, will regular home depot shower tile grout good enough for the tile surround? if not where do I get water proof grout, any links to any sites? I do not think homedepot has waterproof tile grout.
    thank you for the help.
    Home Depot - VersaBond Fortified Thin-Set Mortar (white or gray)
    Do not use the VersaBond to fill in large voids in the tile demolition and remove any thin set bed left on the pool shell (improves tile bonding)
    Hope this helps
