Thread: High or Low PH to kill green algae?
    bait99 is offline ** No working email address ** bait99 0
    Default High or Low PH to kill green algae?
    Hi all,
    Just in the process of getting rid of green gremlins. Almost finished.
    All Ive used is lots and lots of chlorine no algae killers. As for PH, should it be high or low in aiding to kill algae? Right now Im in the high 7's.
    thanks-
    Inground pool
    ~12K gallons
    Indiana.
    Default Re: High or Low PH to kill green algae?
    Lower pH makes chlorine more active.
    Quote Originally Posted by bait99
    Inground pool
    ~12K gallons
    I've seen a lot of claims, both ways, but no proof either way. And, I've not seen any clear difference in the field either. I'd just recommend maintaining your pH properly, based on other concerns, and continue chlorinating.
    Ben
    "PoolDoc"
    PS. While working on the glossary section of the manual for the PS234 today, I ended up checking out some recent research on biofilms. One of the studies examined literature on algal biofims, and noted that there was speculation on this topic, but apparently no actual studies.
  1. Cloudy water after algae kill.
    By spongebob55 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-28-2011, 04:02 PM
  2. Green walls - just can't kill it all
    By PoolFinger in forum Dealing with Algae & Slime
    Last Post: 06-25-2011, 09:05 PM
  3. algae kill in cold water
    By fuelman in forum Dealing with Algae & Slime
    Last Post: 11-17-2007, 01:54 PM
  4. Hard-to-kill algae and SWCG
    By dawndenise in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-19-2006, 06:41 PM
  5. does shocking kill algae ?
    By lenhorn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-31-2006, 09:07 PM
