Results 11 to 14 of 14
Thread: Help - Need information for wiring for an AGP
    May 2010
    Default Re: Help - Need information for wiring for an AGP
    Ditto on the 10 gauge wire. When any electric Motor starts, it requires an initial spike of electricity to start the motor. Once the motor is turning, the amperage draw is much less. This initial spike can trip the breaker if the curcuit is too small. That is one reason why a curcuit that is too long or too small amperage rating will not work properly. As I stated in my original post, a 12 gauge curcuit with a 20 amp breaker is adequate, However, a 10 gauge curcuit with a 30 amp breaker is better. There are 30 amp GFCI breakers available for just about all the different electrical panels. Excellent decision on contacting a Licensed Electrician. Do not let the Electrician talk you out of getting the Building Permit to save money.
    Jun 2010
    Pittsburgh PA
    Thanks again for all the support and information. I went back to the pool store today and upsized the sand filter to a 200lb filter (from the 100lb). I also changed the pump from a 1hp to a 3/4hp hayward. I asked about the 1/2 hp pump and they said they did not carry any.
    On the electric I am going to start calling around for pricing on the install (anyone have any ideas on what is a fair price for the 12 guage 20amp or 10 guage 30 amp breaker install?). The pool company is a little behind so my pool will not be installed until the beginning of July. I will be getting a permit and the wiring has to be inspected by an independent 3rd party. All the other codes are not that bad (10' from the property line, twistlock outlet and the outlet has to be 5' away from the water itself).
    Ben
    That pump/filter size is a much better match. Glad that worked out and that we were able to alert you of the potential mismatch problems before you already had it installed and it was too late to do anything about it. I'll let somebody else address your installation/electric questions.
    Bet you can't wait to get the pool up and running!!!
    May 2010
    Quote Originally Posted by hudson.bh View Post
    Ben
    The cost will depend on a lot of things, mainly your location. I would call or visit local Electrical supply stores or hardware stores and ask the question. I am sure most of those businesses will have lists of Electrical contractors that are more than willing to give you free quotes. Free works so don't be afraid to get multiple quotes.
    Copper wire has seen a roller coaster of price changes in the last few years so a quick visit to the hardware store you give you enough current price info to at least estimate the material costs. GFCI breakers can get pricey.
    As previously stated there is Direct Bury Romex that does not require conduit, as well as plastic, and underground rated flex conduit. I would discuss all of these options with your contractor. The costs will ultimately depend on how you decide to install the curcuit, and how much labor is involved in trenching etc.
  1. Great Information
    By jjsherm in forum General Interest
    Last Post: 06-04-2013, 09:26 PM
  2. New Member Information
    By BWConner in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 02:25 AM
  3. Needing some more information on UV
    By fchapma in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2011, 08:58 PM
  4. Information, please?
    By TX Daisy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-06-2006, 12:34 AM
