Re: The Long Road in Trying to Lower TA
The monochloramine level, which shows up as CC, is 1.2 ppm in my tap water. It is possible that a reading of 3.5 is accurate, though that does seem high since usually water districts target 1-2 ppm for the monochloramine level (for those that use monochloramine for a residual in the distribution system; some are still using chlorine which registers as FC).
