Results 1 to 10 of 18
Thread: Combined Chlorine Issues
    May 2010
    111 Guinevers Retreat
    Default Re: Combined Chlorine Issues
    Received my Taylor K2006 Test Kit yesterday. My Lamotte Color Q was giving me false readings.
    Chlorine Numbers with Taylor kit:
    FC: 18
    CC: 0
    Chlorine Numbers with Lamotte Test Kit
    FC: 15.5
    CC: 3.0
    I'm going to let the chlorine get back down to below 10 and then repost all my numbers with both kits for a comparison.
    18,000 Gallon Inground Pebbletec Pool, Pentair Intellichlor, Pentair Intelliflo Pump, Pentair Clean and Clear Plus Cartridge Filter, Mastertemp High performance Heater, Pentair Screen Logic 2
    May 2010
    Here's my numbers with the new Taylor kit
    FC: 6.0
    CC: 0
    PH: 7.0
    Alk- 90
    Ca- 500
    CYA - 30
    Numbers from my Lamotte Color Q
    FC: 6.5
    CC: 1.8
    PH: 7.1
    ALK: 86
    Ca: 260
    CYA: 26
    I currently aerating the pool to get my pH up to 7.4.
    I'm also going to buy some more CYA and add to get my CYA up to 60 because I do have a Salt Water Chlorine Generator.
    I know the Lamotte tester is giving me a false CC reading. My guess is the Calcium Hardness reading is also false. Let me know what you think.
    Thanks for all your help!!!
    I believe that the Ca reading is also false--if you'll search through the forum, there was a discussion a couple of years ago with another poster on the subject, and involved calls to customer support through the Lamotte supplier, and for some reason that Ca number was false, too. Do some searching and I will too, to see if I can come up with the link.
    Otherwise your numbers look pretty good, if you can get that pH up a little!
    Edit: here it is... http://www.poolforum.com/pf2/showthr...hlight=Lamotte
    May 2010
    I read the article on the Lamotte. A lot of the same issues I was facing with mine.
    Thanks Everybody. Pool is in great shape now. I should be able to keep it that way now with an accurate test kit.
    Great!! Now enjoy that pool!!
    Happy swimming.....
