Thread: Backwashing/Vacuuming--water coming back into pool
    Jun 2010
    Default Backwashing/Vacuuming--water coming back into pool
    We have a Baquapure sand filter and just replaced the entire lid/multiport valve assembly (with a new spider gasket) and changed the sand. Now when I backwash or vacuum the pool, water is coming out the waste adapter plus coming back into the pool. The water only shoots out of the waste adapter half as far as it used to. The algae I'm trying to sweep from the pool is coming right back in. Does anyone have any suggestions? We're not sure if it's something with the spider gasket or possibly one of the laterals. Any help would be greatly appreciated! It's in the 90's, and I really want to swim!
    Default Re: Backwashing/Vacuuming--water coming back into pool
    Something in the Multivalve assembly is either assembled wrong or the new assembly is defective. I doubt it could be much else unless it's plumbed backwards.
    Jun 2010
    CarlD--thank you so much! Your suggestions prompted my husband to check the connection of the hoses to the new multiport valve assembly. When he changed the multiport valve assembly, he reconnected everything exactly the same as it originally was. However, for some reason, the manufacturer reversed the position of the connections. So it was plumbed backwards, and we really thank you! It's time for me to vacuum the pool now so we can swim
    Honesdale PA
    That's what we like to hear. Simple and CHEEP solutions. Welcome to the forum.
    Jun 2010
    Quote Originally Posted by Poconos View Post
    Thank you, Poconos! We were thrilled that this was a simple and cheap solution!!
  1. Intex Sand Filter Problem- i vacuum dead algea from pool floor & it keeps coming back
    By polockma in forum Intex-type Pool Setup & Operations
    Last Post: 08-05-2012, 05:02 PM
  2. There is sand at the bottom of my above ground pool that keeps coming back.
    By confusedpool in forum Pool Equipment & Operations
    Last Post: 06-16-2012, 02:02 PM
  3. Help! Left on vacation and once back pump won't prime and Guests coming over
    Last Post: 09-23-2008, 06:23 PM
  4. Stains coming back?
    By fofa in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-13-2007, 10:44 AM
  5. CYA coming back through returns?
    By HooStat in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2006, 09:57 PM
