Thread: Outward bulging of steel sidewall
    Dec 2005
    Lakewood, CO, USA.
    Default Pics
    Phew. You guys are making me think I don't have to dump 14,800 gallons of water and call in the calvary. It is a very unsettling feeling to see this.
    Default Re: Outward bulging of steel sidewall
    Not to much to worry about there. It's deffinately in the track. Either pushed in a bit or it is higher in the middle than at the posts. I would try to lower it just a little and the buckle should come out. You can use a screw driver or a spade and carefully remove a little dirt at a time and tap the rail down.
    Let us know if that helps, Dennis
    Dec 2005
    Lakewood, CO, USA.
    Default I am amazed!
    You all are absolutely FANTASTIC! We took a pocket knife and started to slip dirt out from underneath the track and ping, ping, ponk, the bulge released itself as we went along...and it looks mahvelous!
    Love you all!!!
    Shelley
    Very glad to here. Hope you get tons of enjoyment out of it this summer.
    Dennis
