Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 52
Thread: Need Help!
    Jun 2010
    Default Re: Need Help!
    This is the kit I bought...
    http://www.amazon.com/gp/product/B00...ef=oss_product
    I added 1.42 gallon bottle of bleach to the pool. I added a little bit at first and then a couple of hours later I checked the level (with a strip), but the color wasn't a bright purple for a high level so I added the entire bottle. I will check it in the morning to see what the level is.
    Jun 2010
    Here is the tool kit I bought.
    I added about 3/4 of a 1.42 gallon bottle of bleach and then tested the water about 2 hours later and the strip didn't show enough in there so I added a little more. I will go out this morning and see how much is in there.
    I thought of something over night. When I first started shocking the pool I added the shock to skimmer forgetting that I needed to add it to water first to let it dissolve. Could that have something to do with it?
    That's the right kit, the Taylor K-2006. You MIGHT have been able to get it for $20 cheaper but over this year alone it will save you that many times over. The main tests you'll use are:
    FAS-DPD for FC and CC
    pH
    T/A (total Alk)
    CYA (Stabilizer)
    CH (hardness)
    I think they have an acid and base demand tests as well but you won't need to worry about them much, if at all.
    Since you have a vinyl pool you'll probably not need to run the CH test more than once or twice during and ONLY if you suspect your calcium levels are too high. I run it at the beginning of the season for a baseline, but only occasionally run it a second time during the summer.
    So go ahead and use your new kit! BTW, the FAS-DPD needs only enough powder to turn the solution red. More does nothing. If one scoop is enough, it's enough.
    Post results for:
    FC
    CC
    pH
    T/A
    CYA
    CH
    Quote Originally Posted by wxwmn02 View Post
    If you have backwashed the filter since you added the "shock", then it has been washed away and won't be available for your pool. If you have not backwashed the filter, then it will dissolve and eventually make it into your pool--after it finishes sanitizing anything that may be in your filter, if there's any left. If you use granular chlorine in the future, you might want to pre-dissolve it in a bucket of water and pour it in , very slowly, in front of a return so that you get the full benefit of it in the pool instead of in the filter.
    Jun 2010
    The kit has shipped so hopefully I'll get it in the next couple of days. I have kept the chlorine level high as you suggested, but still no change. I am beyond curious to know what the calcium level is so if that's the problem I can fix it.
  7. #17
  8. #18
    Jun 2010
    Just got my test kit and the Calcium level or CH is 690ppm. From what I have read in the book that is way too high. How do I bring that down?
  9. #19
    Yep. That is high alright -- just what i suspected. The only way to lower it unfortunately is to do a partial drain and refill. Retest it one more time to make sure you got it right. Actually, why don't you go ahead and post a current set of all testing numbers for everything for us to look at.
    By the way, how does the water look today?
  10. #20
    Jun 2010
    I figured that would be your answer. We will have the other #s for you this afternoon.
