Thread: sand or foam?
    Default sand or foam?
    Which is better for a substrate under the pool?
    New Orleans, LA
    Default Re: sand or foam?
    If you are going to use foam, I would still use some sand. Another good option is Gladon's Perfect Pool Bottom. It is a 30 mil hard plastic sheet that goes under the pool to protect against grass, rocks, etc.
