Results 1 to 10 of 10
Thread: aluminum walls vs galvanized/copper wall
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: aluminum walls vs galvanized/copper wall
    After doing a lot of research that included internet and AG pool books the bottom line came down to a hybrid pool. In terms of cost, durability and warranty the overwhelming advice was a steel/resin hybrid pool.
    We ended up with an Artesian Echo Canyon that came with a lifetime non-prorated warranty. The bottom boots, bottom rail and top seat clamps are all resin. The rest of the pool is steel. Anything that could be exposed to corruption from the soil is resin. All I can say is it's a very sturdy, quality pool.
    What you will find is that each type of material has it's pros and cons.
    Aluminum does not rust but is more flexible and prone to corrosion over time. It also costs more than a steel pool.
    Resin appeared to be an untested product without many years of real world pool trials. I've seen what the hot Texas sun can do to car interiors and other types of resin (plastic) over time.
    For me the steel/resin seemed to make the most sense for the sake of durability and cost.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    Josh,
    Thank you for correcting me that only the higher end aluminum pools are extruded and not one piece as the steel ones are, I did not know that. When I looked at the pool at the pool store I told the salesman more about the extrusion than he could tell me.
    When I bought my pool I did not even know they made ones out of aluminum, the store I bought mine from sells only the steel walls with stainless steel service panel which is what I have. I like the way the Johnny W pools look better than the way the steel walls look, but that pool was a couple of thousand dollars more than mine and I just couldn't afford it.
