Results 1 to 10 of 45
Thread: Ordered My Pool
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Default Re: Ordered My Pool
    Thanks Watermom! I was reading that thread on the apt complex pool and got scared
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    A healthy dose of fear is not a bad thing when dealing with pool chemicals. Knowledge is power and if you are educated about them and use them correctly, you'll be fine. Sometimes people underestimate the potential of danger from seemingly harmless little pucks and powder. That is what gets you in trouble.
    Re: the apt. complex thread --- we were ALL (mods and Ben) getting scared about that one!
    Jun 2010
    Test kit came today. Should be able to get my tap water tested tonight or tomorrow. I'll post results and my predictions for what I'll need here. I'll need your help to make sure I'm not making a bad estimate.
    Got the "hole" roughly dug yesterday. Plan to spend tomorrow afternoon leveling and cleaning up the mess from the bobcat. Hope to be setting patio blocks by tomorrow evening.
    Hard to wait isn't it? I remember the hard work of getting my pool site ready. Thought we never would get it level! One side would be a little high, so we'd take a little bit off. Then, it would be a little lower than another side and so on............
    Wasn't too fun from what I remember, but SO worth it!
    Jun 2010
    Tested pH and Alk for grins from my tap water.
    pH was pretty much dead on 8.0 (not bad for a fish tank )
    Alk hadn't changed colors at 12 drops, so it's higher than 120. I stopped there. I know I've still got some room here with the vinyl pool.
    Looks like I'll be playing a little mad scientist to get things in check.
    Once I fill, what's the first thing to get in check?
    I guess I should work on adding CYA first since it's acidic right? That should lower pH....
    What's the best route here?
    I agree with Watermom, pH and chlorine first, but it won't hurt to go ahead and add your CYA, just don't broadcast it like the label says, and if you add it through the skimmer into a sand filter, don't backwash the filter or retest for CYA for at least 4-5 days because it takes a long time for it to dissolve. Until you have CYA in the water, you're gonna have to make frequent chlorine additions because the sun will eat up a lot of your chlorine, so the sooner you can have it in the pool the better.
