Results 11 to 12 of 12
Thread: High TA in fill water
    Default Re: High TA in fill water
    The saturation index with that high TA is almost +0.8 which is very high and at risk for scaling. Also, the high TA will make the pool have a tendency to rise in pH over time, requiring acid addition (unless Trichlor pucks are being used). You didn't list the CYA level so that could be high and another problem.
    Jun 2010
    Minneapolis, Minnesota, USA
    Duh, I didn't even think to look at the saturation index. It is a brand new AG pool which he just filled, so there was no CYA. He shocked initially with dichlor, so there is a bit now, maybe 6-10 ppm. The sample he gave me was not large enough to test for CYA after the other tests for TA and FC. I told him to buy a FAS-DPD kit so he can keep on top of his chemicals.
    Thanks again for your attention to a newcomer like me. I have been reading this forum avidly for 4 years since I got my pool, so I feel like I know many of you already. I have learned so much from all of you already, but I know there is yet much to learn. It's a privilege to finally be able to register and post here. I hope to eventually be able to contribute as well.
  1. If this was your fill water, what would you do?
    By Bosch232 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2013, 09:13 PM
  2. Fill with only 1 foot of water and don't fill for 24-48 hours?
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 07:00 PM
  3. Ok to fill pool using well water?
    By DanNH in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2011, 12:45 AM
  4. New liner - fill with well water
    By ksturge in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2007, 03:19 PM
  5. my fill water test
    By gordyjamz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-23-2006, 02:09 PM
