Cant Get FC To Increase
I was having trouble with clearing my green pool and found the CYA was extremely high, so I drained about 2/3 of the pool and refilled to correct. In the mean time I ordered a Taylor K2006 test kit. I have an inground 18,300 gal pool and the first test 3 days ago had these results:
FC=.5
CC=2
Ph=8.0
TA=110
CH=300
CYA=45
I have since lowered the Ph to 7.5. Everything else is in line except the chlorine. I still have some green so I am trying to get it to shock level of about 15. Over the last 3 days I have put in 7 182oz bottles of bleach and this morning the FC=0This just doesn't make sense. I have a question about the DPD powder that came in my kit, is it supposed to be lumpy or clumped together? It says to add 2 dippers and mix but it doesn't dissolve completely. I had to put like 7 dippers for it to become only slightly pink this morning. Any ideas? Or do I go buy a pallett of bleach from Sam's?
