Re: reuse liner
Have not been by here in a while. How did the pool move go? Perhaps you've found that the biggest problem would have been to get the "holes" (skimmer, returns) lined up. Often, an easier solution is just to put a patch over the existing holes and line them up with the patched piece. Trying to use the same holes will often result in the liner tearing out at those spots as it is filled. Sorry if I'm too late...
