Results 1 to 10 of 43
Thread: Help Deciphering My Taylor Test Results
    labdi01 is offline Registered+ Thread Analyst labdi01 0
    May 2010
    Default Re: Help Deciphering My Taylor Test Results
    Update: Tested FC and CC again (4 hours after initial test this am). Good news. FC up to 22 and CC down to (barely) 1.5 - pH holding strong at 7.2 - surprisingly with all that FC.
    Questions: Let's say hypothetically, my CC gets down to 0 today, what do I do next? Just let the CL levels come down on their own? Should I do a maintenance dose of polyquat 60 and if so, when (now, or when CL is down)? And should I do that weekly? Once all numbers are in check, how often should I be testing/balancing my pool in 'maintenance mode'? How do I know I need to shock (I know after considerable rains)? Whenever CC is above .5?
    Dianna
    New owner of 24' above-ground pool, vinyl liner, 1 hp pump and sand filter, added D.E.
    Once you go with losing no more than 1ppm of chlorine overnight and have no CC, I think I would maintain the high cl level for one additional day for insurance. Then, if all is still good, let it drift down.
    It won't hurt to do a maintenance dose of polyquat once you are past this, but remember it will make your cl plummet. That is ok, but just be aware and be ready to add some bleach.
    Once you are in maintenance mode, you need to test at least once a day. You shock when you have any CC above 0.5 and maybe after a heavy rain that may put a lot of organic debris in your pool or after an exceptionally heavy swimmer load.
    May 2010
    Thanks Watermom!
    I just tested FC/CC again. My FC went down to 16 - but my CC is 0. I'll add more CL and get it back up to 20.
    My CYA was still right around 30, so I put my CYA sock back in (there's maybe a 1/2 pound left in it). Was that wise? Is 50 the goal I'm reaching for with CYA?
    (can kids swim while we're doing this?)
    Dianna
    May 2010
    Not sure what's going on. For about 8 or so hours yesterday, I got my CC to 0 and held on pretty-well to my FC levels around 22. It was overcast most of the day.
    Suddenly, mid-day my FC dropped (by 8 ppms - twice) and my CC went back up (to 1.5). FC held at 25 overnight - but so didn't CC at 1.5.
    I also did a polyquat treatment yesterday evening. The only other thing I did before the change, was brush part of the pool.
    Question is - FC and CC are holding strong. Should I up the shock level?
    Dianna
    Lehigh Valley, PA
    Sure, the kids can swim while the CYA is in the sock, just don't let them go play with it and squish it around.
    The recommendation in a non-SWCG pool is for CYA to be between 30 and 50.
    Good job getting that CC down!
    May 2010
    CL didn't plummet, though - weird. Because CC is holding tight (as is CL), should I take shock level above 25 (where it's holding now)
    Dianna
    If your CYa is still 50, I wouldn't take it above 25. Since this thread has gotten pretty long, can you please post a new, current set of numbers for us?
    May 2010
    Thanks for responding Aylad.
    Just ran new tests:
    FC - 19.5
    CC - 1
    pH - 7.2
    TA - 130
    Dianna
