Hardness question
We just got a new house with a 7500 gal above ground vinyl pool. It was dark green and murky so we drained, cleaned, and refilled. Just tested it and the total hardness was 1000. I have heard that that is not good, but don't know how to fix it. Also, the total alkalinity is 180. How much acid should I add? And do I need to adjust all this before I add chlorine? Thank y'all in advance.
- You may not post replies
- You may not edit your posts
Forum Rules
