Results 1 to 4 of 4
Thread: Filtering Problem
    Angry Filtering Problem
    I replaced the DE grids and I still have minimal filtering. I can see debris reentering the pool as I am vacuuming. What could this be?
    Default Re: Filtering Problem
    Welcome back to posting!
    Have you checked out the multivalve internals?
    Also, when you replaced the grids, did you make sure that the fabric was all the way up to the 'inports' on the manifold and that the manifold itself wasn't compromised?
    We'll help you, but you've gotta be our eyes, as we can't be there to see for ourselves
    Please answer our 'follow- up' questions, and the great group here will guide you to a solution
    Quote Originally Posted by waste View Post
    Will check the multivalve and grids tomorrow. Thanks!
    Question Re: Filtering Problem
    Took apart the filter and reset the grids, even though they appeared fine. Saw that the screen to the PENTAIR STRAINER AIR RELIEF had rotted out, so I ordered a new one. Don't see how this would be a problem with the return, though. Replaced the gasket to the multivalve which was fairly compromised, thinking problem solved. Started the pump and once again, saw DE entering the pool. Vacuumed the pool of debris and once again the stuff returned. Really hoping that the strainer air relief is the problem. Any ideas? Thanks!
  1. Solar cover doesn't allow for good filtering
    By Jacob99 in forum Pool Equipment & Operations
    Last Post: 05-22-2012, 03:33 PM
  2. questions about pumps and filtering for above ground pool
    By slow96z in forum Pool Equipment & Operations
    Last Post: 07-25-2011, 02:38 PM
  3. Filtering out calcium
    By poolEd in forum Dealing with Alkalinity and Calcium
    Last Post: 07-17-2011, 06:53 PM
  4. Polyquat filtering out??
    By KirstenHW in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-08-2006, 11:33 PM
  5. Filtering well water into autofill
    By kearpaul in forum Pool Equipment & Operations
    Last Post: 08-23-2006, 01:55 PM
